Rakes
Rob MO.
06-07-2001 15:32:00
There is an action coming up & there are 2 side delivery rakes. One is a New Holland #55 & a Case. Is the #55 a 2-wheel or a 4-wheel. Same question on the Case
Jerry D in NC
06-08-2001 08:03:30
 Re: rakes in reply to Rob MO., 06-07-2001 15:32:00
The NH 55 was the first of the NH Rolabar Rakes that started production in '55. They were made for 3-4 years and the Super 55 was introduced for a year or two and then the 56 was released. The 55 did not have the offset rear end which helps the rake track closer to the ground as it is being used. The 56 was the first to incorporate that. Unlike the 56 on up models, the 55 is almost completely red with only the wheels and basket support angle iron being the yellow. I really am interested in how much the 55 brings at auction if you don't mind posting. Around a $1000 would seem about right if it was in decent shape. A 56 and later in good shape will bring an average of $1200-$1400 and the only real difference is the axle setup. Parts for the restoration of mine have been easy to get from the NH dealer with most of the parts interchanging with the current models so that is not a major issue.
paul
06-08-2001 09:03:31
 Re: Re: rakes in reply to Jerry D in NC, 06-08-2001 08:03:30
Around 'here' the 55 would bring closer to $500, while the newer models bring $1000-15000.
'Here' the NH models bring the most, JD also sells well, then there is all the rest for a couple hundred $$$$.
Oh, the 55 is 2 wheel, altho it is possible it has a front dolly wheel.
--->Paul
Steven M
06-07-2001 18:36:27
The New Holland 55 was built 2 wheel. I have a 56 it was a 2 wheel but i put wheels on the front of it, i like it better that way. As for the Case i think it would be 2 wheel.
