IH 56 baler HELP!!!!!!!!!
mike jenezon
06-04-2001 19:18:23
help has anyone used a 56 baler i am having problems with one knife cutting the twine the other works fine they are adjusted as per the book and it still wont cut it is sharp but i am using plastic twine has anyone ever used plastic in a 56 and had it work or had i better use sisal i'd rather use plastic cause mice dont eat it tia mike
Jerry D in NC
06-05-2001 01:03:40
 Re: IH 56 baler HELP!!!!!!!!! in reply to mike jenezon, 06-04-2001 19:18:23
I am not that familiar with the IH knotters but did you adjust the twine disc. Did it work with sisal and you just put in the poly? I would recommend checking the manual and go through the setup aettings and check all of the tensions.
mike jenezon
06-06-2001 23:39:54
 Re: Re: IH 56 baler HELP!!!!!!!!! in reply to Jerry D in NC, 06-05-2001 01:03:40
yes i've been through the timing and settings about 6 times went and got new knife inserts tuesday and will see if that helps
Jerry D in NC
06-07-2001 03:59:25
 Re: Re: Re: IH 56 baler HELP!!!!!!!!! in reply to mike jenezon, 06-06-2001 23:39:54
Now I am by no means a IH Knotter expert but what is the tension set for on the twine disk. That turning loose about the only thing that will keepit from cutting the twine in all of my references.
