Mower
walter
06-03-2001 14:50:22
i just bought a vicon cm165 disc mower needs a little work bearings i think but it does run. but i can not find any dealers in upstate s.c. i would like to have a owners manual and or shop manual before i jump into this thing head first, i have had acouple of other dealers "say" they can get me parts i would appreciate any help i can get. thanks, walter
Burrhead
06-03-2001 20:40:05
 Re: mower in reply to walter, 06-03-2001 14:50:22
Just about any JD dealer should be able to get the manuals for you.
On the bearings I would knock a set out and go to Motion Industries or some sort of industrial bearings joint to get them. It will save you about a million bucks.
If it's just bearings and blades the vicon is simple enough to work on just watch how you take it down and it's not bad. Just be sure to keep the shaft joints in line and that keeps it balanced
walter
06-09-2001 18:21:25
 Re: Re: mower in reply to Burrhead, 06-03-2001 20:40:05
thanks for the info, i was thinking the same thing on the bearings, here it's Dixie Bearing Co. didn't know jd carried vicon parts it probably wont lay none down this year but mabey next yr thanks again walter
