JD N manure spreader
Randy
06-03-2001 04:28:23
We have a old JD N manure spreader, that needs repair. Is it worth repairing? Can you get most parts for it? Thanks for any help.
Mike
03-29-2002 21:10:02
 Re: JD N manure spreader in reply to Randy, 06-03-2001 04:28:23
We also have an N spreader, and are looking for the double sprocket on the right rear end of the spreader that drives the beater. Have had no luck finding one thus far.
F14
06-03-2001 10:12:50
I had no trouble getting parts for a JD H manure spreader from late 40's/early 50's. Whether or not it's "worth repairing" is up to you. If it needs sheet metal for bottom or sides, the cheapest way to fix it is get the sheets precut from a steel jobber. Central tractor has the apron chain. The rest should be available from JD.
If you've priced new "estate spreaders" (small ground drive spreaders for the horsey set) it'll become immediately apparent that sinking even as much as $1000 into your spreader is money well spent.
