White 2-150 drains batteries
Dean
06-01-2001 14:28:21
There is some battery drain while the key is off. Is there anything in particular that I should suspect on this tractor? Generator, key, etc. Thanks in advance.
larry
06-04-2001 18:36:16
 Re: White 2-150 drains batteries in reply to Dean, 06-01-2001 14:28:21
There is a seloniod that turns on the cab electrics it can stick in the on position. the amount of drain varies depending what is turned on in the cab. it's in front of the dash and under fuel tank.
Mark
06-03-2001 04:43:00
Had a similar problem on my oliver 1655 last summer, I finally found out that there were small cracks in the battery cable between the battery and the starter motor that was causing a drain on the battery, Good luck.
