As the other said, for mowing you want to run at pto speed - near full throttle usually if you don't have a tach. I'd start in your slowest gear, get comfortable, and move up from there - probably always be in a slower gear. (For safety, does your tractor have independent pto???? If not, GET an overrunning pto adaptor. For more info, search the archives for 'over running pto'.) I really enjoy the row cultivator stories - relate to some of them. :) However, JT, I don't think you quite said it right - cultivators don't have 'bottoms', they have 'shanks' if they are a field cultivator that stirs up all the soil, or 'rows' if they are a row crop cultivator to weed between rows of a growing crop. (Plows have 'bottoms'.) I suspect you meant you have a small field cultivator with 6 shanks on it - you really can't have a 6 row cultivator only 6.5' wide. :) So, for this implement, you might as well start out slow as well. eventually you want to go about 3-5 mph. This will depend on how good your tractor handles it, what type of soil you have, how many/ how big the rocks are, and how rough the ground is under you. Basically you want to get done as quick as you can, without shaking you or the tractor & implement apart, or tearing it up on rocks/ potholes. If your tractor is diesel, you want to run close to full throttle most of the time & adjust speed with the gears. (Best for engine & ecconomy.) If your tractor is gas, you want to be about 3/4 throttle when that works, or near full for pto work. --->Paul
