Round bailer
George
05-17-2001 07:14:11
I have been thinking of going to a round bailer as I am getting older and putting up 500 or so bales of hay a yr, not a lot but realy hard to do myself as the boys are long grown an gone and you just can't hire anyone today, they rather flip burgers at Mickey Dee's.What would be a good ol' inexpensive round bailer (I can fix/maintain anything)! the ol' I.H.45T has been a good ol bailer if you don't run it too fast,BUT I can't figger how to drive the tractor and stack hay on the wagon at the same time. Then you got to stack it in the hay barn, just too much handling.
Big Jim
05-17-2001 10:10:58
 Re: Round bailer in reply to George, 05-17-2001 07:14:11
George,
I don't know what area you're from or how many acres you plan to bale. I have used many different round balers and do custom baling also. I would recommend getting a round baler with "open throat" design. That is to say- no press rollers. However if you want to go real cheap you can buy an older round balers like a Gehl 1500 or IHC 241 for $1,500 or less in our area (Wisconsin). The older balers all make the larger bales (5'x6') and will cause you a lot of grief unless your hay is perfectly dry. Even a little dampness will wind up the hay on the press rollers. Personally, I would spend a little more money and get a baler that makes the 4'x5' size bales with open throat design. Your talking about $4,000 up to $$$$$. Just my two cents worth.
George
05-18-2001 06:47:43
 Re: Re: Round bailer in reply to Big Jim, 05-17-2001 10:10:58
Big Jim,
Thanks for the reply, I am putting hay up from 3 acres, not much just enough for 6-8 cows/steers here in S.E. Michigan hate to spend 4 grand for such little acres/bales maybe have to find a kid to drive the tractor after all. heck after 23 years with the ol' 45 T. I wouldn't know how to change anyway, but it is getting to be a problem ol' auther riteous is getting to be a constant companion thanks, George
paul
05-18-2001 12:55:49
 Re: Re: Re: Round bailer in reply to George, 05-18-2001 06:47:43
I know what you mean - I put up 5-6,000 bales a year. My wife drives tractor most of the time, but I'm the bale handler. And stupid me, I passed on a good 605H for $2100..... Sigh. What was I thinking.....
Anyhow, around here the Vermeer's go a little cheaper than the red or green machines, and folks say they hold up well. Hum, after the 'C' model is the open throat designs?
--->Paul
jerrya in Indiana
05-19-2001 12:16:48
 Re: Re: Re: Re: Round bailer in reply to paul, 05-18-2001 12:55:49
Big round balers are in big demand today.Yet there are a lot of good used ones out there for sale.I also lean towards the open throat style.They seam to not wrap at the rolls when hay is just barely dry enough to bale and the clouds are rolling in.They seam to hold their value also.Hope this helps,GO FOR IT...
