New Hydraulic Cylinder
Jim Smith
05-16-2001 08:49:45
I have never had to setup a new hydraulic cylinder. Now I have to put one on a mower conditioner. I have the hoses and connecters, but how do I setup the cylinder? Do I just hook it up to the tractor and pump oil in it, or do I have to vent out the air some how?
Sam (MO)
05-16-2001 10:04:54
 Re: New Hydraulic Cylinder in reply to Jim Smith, 05-16-2001 08:49:45
Jim
I had to repair my cylinder on my NH478 two weeks ago. I don't know if I got lucky or what. Just hooked it to the tractor and raised and then lowered it a few times. It seem to get faster after the first time. I did need to top off the HYD fuild. My 2 cents. best of luck.
Sam
Burrhead
05-16-2001 19:11:13
 Re: Re: New Hydraulic Cylinder in reply to Sam (MO), 05-16-2001 10:04:54
That's right Sam. You just run it all the way in and out a couple of times and it will bleed itself.
Erin, MT
05-16-2001 19:19:29
 Re: Re: Re: New Hydraulic Cylinder in reply to Burrhead, 05-16-2001 19:11:13
They won't always bleed themselves. The loader arms on my tractor point up, so the air will always be there if you dont put them in right. I have quick disconects on my hoses, so I remove the hose, extend the cylinder manualy, and fill the cylinder. reconnect hose, and push in the valve on the disconnect while I compress the cylinder until fluid comes out. then connect to manifold, or junction.
