U-Joint
Pine Grove
05-09-2001 06:23:41
Post hole digger with broken u-joint, no cups or snap ring with this u-joint, looks pressed into pto shaft yokes, U-joint itself hinges or moves on studs protuding from it. Actually it works backward from the conventional U-joint which hinges or moves by bearings located in outer cups.
All assist appreciated.
RickB.
05-09-2001 09:28:57
 Re: U-Joint in reply to Pine Grove, 05-09-2001 06:23:41
The only way to disassemble this joint is to cut away the center pivot block with a torch, then drive the pins out of the yoke towards the center of the yoke. The pins are a press fit, knurled and are non-reusable. This is a low-speed low-cost (to make) joint. You will probably have to find a dealer for the brand of PHD to get a replacement. Gehl used a similar joint on the driveline of a 970 forage box (I think). You might try a Gehl dealer if there is one in your area, but it's a long shot at best. You may have to buy 2 yokes to match the shaft configurations and convert the joint to something more conventional.
Pine Grove
05-09-2001 10:22:35
 Re: Re: U-Joint in reply to RickB., 05-09-2001 09:28:57
Just what I figured, thank goodness I have a couple of old pto shaft ends hanging around, just have to fab. to fit/work. thanks
