Jones MK12T Baler, oh darn, broken shear bolts!
Campbell
05-09-2001 01:35:37
Recently purchased one hay baler from one 'not so careful' owner.
Shear pins broken on flywheel AND needle swing arm. Looks as if new crank has been fitted to drive the needle swing arm but suspect it's not adjusted correctly.
Can anyone please advise;
1) How to set the timing on this model baler?
2) Should the shear bolts be mild steel or high tensile steel (or anything else for that matter!)?
Many Thanks
