Old Tekonsha Brake Controller
JD
05-07-2001 16:30:48
I have an old Tekonsha brake controller, the kind that plumbs into the master cylinder brake line. It also has three wires, red-blue-black. These obviously hookup to ground, 12V, and the trailer connector but which is which?
I've checked the web. Found plenty on the new micro-processor based controllers but nothing for mine.
Bob Collins
05-08-2001 05:01:29
 Re: Old Tekonsha Brake Controller in reply to JD, 05-07-2001 16:30:48
Brad, Don't plumb your brake controller into your hydraulic system if your truck has anti-lock brakes, I understand this can cause problems.
JD
05-08-2001 13:52:30
 Re: Re: Old Tekonsha Brake Controller in reply to Bob Collins, 05-08-2001 05:01:29
Wasn't Brad, it was me. I don't have ABS but thanks for the heads-up anyhow. Until they come up with some sort of industry standard TWO-WAY communication between the ABS & the controller, ABS is going to have problems even with the digital ones.
Brad Bottom
05-07-2001 21:41:32
Blue - runs back to the plug on your truck for the brakes
Red-is your HOT wire .
Black- is your Ground wire.
JD
05-07-2001 22:37:54
 Re: Re: Old Tekonsha Brake Controller in reply to Brad Bottom, 05-07-2001 21:41:32
Thanks Brad. Just what I was looking for.
p.s. I have one of the micro-processor "smart" controller suggested by Charlie but I wanted to try this one - sometimes simpler is better.
charlie
05-07-2001 17:02:09
i replaced all of my hydraulic controllers with the fully electric.no more leaks and they work every time.check ebay and see whats on there.i bought four brand new ones off there and saved a good chunck of change.good luck
