Sickle mower; dearborn model 14-16 (need info)
dan
05-04-2001 07:37:52
anyone familiar with these? need manual, bar parts
Tom-Pa
05-04-2001 11:35:20
 Re: sickle mower; dearborn model 14-16 (need info) in reply to dan, 05-04-2001 07:37:52
Dan,
I have a 14-16 and you need several additional parts to use the mower. You need a false toplink attach point (goes below the regular toplink attach point) 2 ea. 8 inch extentions to lower the lift arms, and a special under rt axle bracket. it has a ball below the stabilizer pin. And, to top it off, I highly recommend you get a parts manual,,and instructions..they are available thru the N-Newsletter archives. I listed the link below.
Good luck,
Tom-Pa
here it is written out, had some problems.
dan
05-04-2001 17:21:58
 Re: Re: sickle mower; dearborn model 14-16 (need info) in reply to Tom-Pa, 05-04-2001 11:35:20
thanks, it hes 3pt setup & side draft rod, right side, although my tractor is not equipped with 3pt as it is a pony tractor. will try to build attachment for it.
