Universal Joint
Charles story
05-03-2001 10:37:55
Have John Deeere post hole digger, I have broken a universal joint, the universal joint is different from others I have seen, in that it uses no caps or locking snap rings, appears to be pressed in pto yokes. Really need to find replacement universal joint. All help appreciated.
Russ
05-04-2001 18:08:08
 Re: Universal Joint in reply to Charles story, 05-03-2001 10:37:55
Charles, can`t offer any knowledgeable insight on this particular joint, but maybe a general tip. Around here, upstate NY, we have a business called Universal Joint Sales, they repair and rebuild just about any kind of driveshaft known to mankind. It`s usually cheaper and easier to go to them than it is to buy the parts and do the work yourself. Must be the volume. There is probably a driveline rebuilder near you who could solve your problems. Good Luck
Knut
05-04-2001 06:00:18
Some of those old units had a joint assembly where the two yokes and joint were factory assembled and the cross assembly cannot be replaced seperately.
Usually name (Neapo, Blood, Cross, Spicer, etc) is stamped or cast in the cross and assembly can be bought or replaced with repairable type from Napa or parts house with pto parts.
Jerry D in NC
05-03-2001 11:40:01
Ran into one like that last week. Neighbor smarter than me found that the snap rings were on the inside and that it was like a normal universal joint. Look just inside the yoke and see if you have the snap ring there. If so remove it and press the caps out as you normally do. This was on a NH 55 hay rake
Charles story
05-03-2001 11:47:21
 Re: Re: Universal Joint in reply to Jerry D in NC, 05-03-2001 11:40:01
Checked that but no luck, looks like 1/2 dia. studes were pressed into pto yokes then into body of universal joint.
Jerry D in NC
05-03-2001 11:51:39
 Re: Re: Re: Universal Joint in reply to Charles story, 05-03-2001 11:47:21
Never heard of one like that either. Dig close because we looked and looked before we found the inside one. Looked like the shoulder on the casting. To get better help here you might want to list the what it came from. That will help some one remember.
Charles story
05-03-2001 12:02:58
 Re: Re: Re: Re: Universal Joint in reply to Jerry D in NC, 05-03-2001 11:51:39
John Deere Post hole digger do not know model #
marlowe
05-03-2001 19:44:53
 Re: Re: Re: Re: Re: Universal Joint in reply to Charles story, 05-03-2001 12:02:58
sounds like a u like on new cars they use plastic to hohd the caps in use a tourch to heat the cap and the plastic will melt you will see it run out but be carfull some times the plastic will spit out the new u will have c locks
Charles story
05-04-2001 09:02:47
 Re: Re: Re: Re: Re: Re: Universal Joint in reply to marlowe, 05-03-2001 19:44:53
No, checked, steel on steel, probably early 60's model, shed kept.
marlowe
05-04-2001 10:21:54
 Re: Re: Re: Re: Re: Re: Re: Universal Joint in reply to Charles story, 05-04-2001 09:02:47
you got me never did like JD stuff
Pine Grove
05-04-2001 11:39:11
 Re: Re: Re: Re: Re: Re: Re: Re: Universal Joint in reply to marlowe, 05-04-2001 10:21:54
I'm about to say the same.
