One bottom plow
geo dolak
04-28-2001 19:14:49
I am looking for info on setting up a one bottom plow. 3 pt. hitch. I can't get it to turn over the sod evenly. I get an area betwiin the row about the same size as what turns over. Any help would be appreciated. Thanks Geo. Please use my email. thanks
Bob McCammon
04-30-2001 09:16:54
 Re: one bottom plow in reply to geo dolak, 04-28-2001 19:14:49
Be sure that the bottom is not trying to turn over more than it is designed for. A 14" bottom should only cut and turn 14". If the plow cannot be set over on its frame, be sure the right hand tractor wheels are set in as close as possible. Then with the wheels in the furrow adjust the plow to run level front to back and side to side. Good luck.
