Lubrication on Sickle Bar Mower
Brian
04-26-2001 09:45:50
Just preping my IH sickle bar mower at this time. My question is what type of grease do you use for the mower bar if you are cutting hay? I figure any old grease will do but would appreciate confirmation on my guess. Thanking you in advance.
B.C.
04-27-2001 06:36:01
 Re: Lubrication on Sickle Bar Mower in reply to Brian , 04-26-2001 09:45:50
Granddad always claimed that oiling the sickle didn't do any good because it just rubs off in a few minutes anyway. If you go through dry sand or dirt before that it will attact that all the more.
The juice in the hay stalks tends to lube the bar anyway.
The pitman bearings and associated machinery usually need periodic lube of some sort. An owner's manual should tell how.
B.C. Some More
04-28-2001 09:42:33
 Re: Re: Lubrication on Sickle Bar Mower in reply to B.C., 04-27-2001 06:36:01
I should add that I pull the sickle out of the bar for the winter, along with the wooden pitman rod. These go in the garage. The rock guards on the bar get a coat of rustoleum. Seems to work. Doesn't wash off the way oil would.
paul
04-27-2001 07:11:15
I agree with these ideas. Oil over winter, but I don't want the oil in my hay, & it doesn't stick around anyhow.... Plant juice should do it.
--->Paul
sammy the RED
04-27-2001 09:54:02
 Re: Re: Re: Lubrication on Sickle Bar Mower in reply to paul, 04-27-2001 07:11:15
You dont keep oiling it in the hay field. When you first get it out from the shed and are checking it out makeing sure that everything is good to go. You put some oil on it so that it does not start dry. How much oil do you really think will get on the hay ?
paul
04-28-2001 08:50:17
 Re: Re: Re: Re: Lubrication on Sickle Bar Mower in reply to sammy the RED, 04-27-2001 09:54:02
Well, I can agree with you then. :)
Altho, how much used motor oil is too much in 'your' food supply???? ;) Just a thought.
--->Paul
sammy the RED
04-26-2001 21:43:02
Used motor oil. It was good enough for my grandad and my uncles, its good enough for me.
rhudson
04-26-2001 20:12:49
My dad always used burnt motor oil. i sometimes use graphite spray on or oil base. (tractor supply). like Ray, i don't think it matters much 4 hours into the cutting day. i put up mower at end of season with burnt motor oil to prevent rust.
RayP(MI)
04-26-2001 19:03:04
Probably the juices from the plants you're cutting will provide sufficient lubrication. Do you really want to put oil or grease on the hay you'll be feeding your animals? For storage it might be advantageous to coat with a little used oil to prevent rust. Most will be dripped off by the time next haying season rolls around.
Farmer-Gene
04-26-2001 18:02:46
I always use used motor oil, good way to get rid of it. The oil won't stay on the sickle bar very long anyway nomatter what you use.
Jerry D in NC
04-26-2001 13:27:12
Personally I use chainsaw bar oil. Good lub and a bit tackier makes it stick a bit better than used motor oil.
Jlasater
04-27-2001 11:11:21
 Re: Re: Lubrication on Sickle Bar Mower in reply to Jerry D in NC, 04-26-2001 13:27:12
Combines don't run any sicklebar lubrication at all. Most of the parts are made of alloy steel that's plenty hard to wear a long time. I'd just shoot everything with WD40 for storage, and don't use any lube when cutting. If in doubt, call a local implement dealer, they'll probably say the same thing.
