Shaft seal replacement?
OCB
04-22-2001 18:18:25
I have a bush hog that leaks grease from the lower shaft below the differential gear box. I would like to replace the seal. This is Similiar to a JD Model 207 (Pull type), Does the gear box have to be removed, to remove the top horizontal shaft before pulling the the gear from the vertical shaft. The shaft has to go down and as you can see I'm looking for an easy way.
Thanks.
