Needs lots of advice!!!
David
04-17-2001 11:33:14
I just got two tractors - a 25HP and a 40HP with loader. Now I need lots of implements for maint. around my 44 acres. I have a 6' mower, 60" box blade, and a B600 3ph backhoe. Please jump in and give any advice on the following or correct my thinking since I am a newbie and don't have much experience here. I need a 3ph sickle bar to mow along the sides of the creek banks and drive way? -what kinds should I look for?
A 3ph chipper/shreader to chew up the fallen and cut back limbs along the roads and trails instead of dragging them off?
Post hole digger w/6" auger for post holes?
kevin
04-18-2001 18:09:20
 Re: Needs lots of advice!!! in reply to David, 04-17-2001 11:33:14
Rotary mowers are scary ... I used on for a summer to clean up fields that had been overgrown for 10 years. Hit a rock and you'll know it. I found all mine now ... the bush hog is retired, the rocks are gone and this year I'll use a 8 foot hammer knife mower. The rotary really scares me. As for the garden ... I went through it, used a tiller on the back of the tractor and was quite happy with the job. Better to rent one of these units when you need it. Do yourself a favor and spray everything you plan on tilling with roundup when it turns green or you'll just keep getting weeds especially twitch grass... been there done that and ended up tilling the garden all summer with the ariens to get rid of the twitch.Buy roundup at the farm supply as it is about one tenth the price as the landscape store
My $.02
paul
04-18-2001 10:29:18
Do you mind if I ask some tough odd questions? I'm just trying to help, really. :)
You have a real impressive list of things you want - but what do you NEED? Where do you want to end up? What's the goal here?
What's the post hole digger for? Are you going to run livestock? You are using wooden posts then? Otherwise using steel posts, kind of a waste of money for only digging 6-8 corner posts on your small acrage.
What's the chipper for? Only costs you money to grind up the wood, and throw it in a pile - just drag it off & throw it in a pile - same difference, much cheaper, much safer.
What's the tiller for? You doing a big garden - sounds good. You want to plant 20 acres of farm crops? An old plow, disk, & harrow(drag) would be cheaper & better & less power & less parts to buy. (By the way, for a tiller be SURE your tractor has a very slow low gear - very slow!)
Be careful mowing dich banks. I do every year - but if you are new to this, it is VERY dangerous. You can get pulled in real quick. Might want to just clean up the weeds a little & let the bank grow native - folks seem to want us to leave them alone these days anyhow. You'd like a sickle with a breakaway, and pitmanless so it will cut well while flexing up & down the banks - altho, I mow mine with a Ford 501 pitman, & the breakaway broke & dad welded back together...
The disk mower will cut through more things, but costs dearly, can be dangerou around rocks, and will be much heavier, which makes it more dangerous on those ditch slopes....
Wish I had a backhoe. Just can't afford it. But then, I'm trying to actually farm! :)
Now for those ready to read me the riot act: David asked for advise. Mine is just kind of a reality check. All this stuff is just wonderful, but is it needed? We aren't hearing what it will be used for. If you have that part all thought out, & you have tilling jobs lined up, & you plan on putting in 500 wooden posts, & there are local burning bans & there is no good place for a brush pile on your place, and .... Hey, like I said, it sounds like a great list of machinery. I'm just not sure it's what you NEED. If it's what you WANT, go for it, enjoy, have fun. :) And play safe.
--->Paul
David
04-18-2001 13:19:50
 Re: Re: Needs lots of advice!!! in reply to paul, 04-18-2001 10:29:18
Thanks for the reality check Paul. I need this stuff for basic landscaping I guess.
Chipper/shredder - The limbs along the roads on my lands have to be cut back every year so I can get the truck and tractor down to the lower lands and creek. I have no where to pile them and I can't burn them. Not sure If I need a 3pt shreader or just a 10hp roll around.
Posthole digger - I will be putting down about a mile of split-rail fencing along my driveway in hard rocky soil in addition to corner post on the lower field.
Tiller - Will be doing a medium size garden and loosen/turning some bare rocky spots so grass will grow.
Sicklebar - I used the backhoe to put 24x24 ditches down both sides of my driveway to stop the wash-over during our heavy rains and now need to mow over those ditches and I have two wet weather creeks and a full time creek that I need to mow the 3-4 foot weeds along the banks. At present I make half moon passes with my 6' mower letting it slip off the edge. SCARY! The ground is level though.
Warren
04-18-2001 07:39:30
David,
I think that you will find that a good hydraulic loader for the 40 hp tractor will be about the handiest piece of equipment you could want.
Sven
04-18-2001 07:38:16
I've got a JD 38 sickle bar and it works great for cutting grass, small dia trees, bushes etc. best things about it are doesn't need much HP and angles up and down for ditch work. Parts were still available. One last thing, if you get a sickle bar make sure it has a good break away mechanism. This comes in handy when you accidently hit big trees or other stuff. Kind of scary if you have dogs though.
F14
04-17-2001 14:09:22
Your list looks good to me.
On the tiller, the only thing I'd recommend is to be sure the drive train is protected by a slip clutch, and keep the slip clutch adjusted and maintained.
You may want to look into a small disc mower rather than a sicklebar. Works better on brushy stuff, cheaper to replace knives when you whack one on a rock. More expensive to buy intially, I'm pretty sure.
David
04-17-2001 14:13:28
 Re: Re: Needs lots of advice!!! in reply to F14, 04-17-2001 14:09:22
dealer tells me a disc mower needs 45plus hp!
Are there any that require less HP?
F14
04-18-2001 04:52:55
 Re: Re: Re: Needs lots of advice!!! in reply to David, 04-17-2001 14:13:28
I ran a small disc mower with my 20 horse JD750 compact, so your dealer is trying to sell you too big of a mower (or a bill of goods). The only reason I traded mine is that it was too heavy for my little tractor.
Folks tell me I can't run a 5' rotary mower with my 20 horse tractor either, which is odd, considering I've been doing it for 12 years, and cutting some pretty impressive brush with it, too...
Stan
04-18-2001 07:15:26
 Re: Re: Re: Re: Needs lots of advice!!! in reply to F14, 04-18-2001 04:52:55
I ran a 5' A-C brand cutter(I call all of 'em bush-hog)with a JD MT, which is 'bout 20 HP, for several years, also cutting some pretty tuff stuff. It can be done, but it sure was a hard way to go! Had narrow front, had to really be careful bout hidden rocks, holes, etc. Guess I wanted to work harder then, than I do now.
F14
04-18-2001 08:33:06
 Re: Re: Re: Re: Re: Needs lots of advice!!! in reply to Stan, 04-18-2001 07:15:26
I'll bet! My 750 is wide front, FWA and diesel, which makes it somewhat easier. Don't do commercial cutting anymore, too hard on the ol' back bouncing around in them fields.
David
04-17-2001 13:16:59
One more thing. I need a 3ph tiller. I notice that a lot of tillers have different options/adjustment/controls. What should I look out for?
Thanks for all the advice!
Ken
04-18-2001 08:55:42
 Re: Re: Needs lots of advice!!! in reply to David, 04-17-2001 13:16:59
Just get one of those tillers that come over on the grey market tractor like Yanmar. They are cheep and work great.
