Rubber planter press wheels, smooth or lug?
JWS
04-16-2001 14:06:35
I have two JD 494A corn planters I am getting ready to use one the other is for parts. One has smooth rubber press wheels and the other has lugs like a tractor on it. Which do you think is better to use with silty-clay soils?
Rick
04-20-2001 16:45:18
 Re: Rubber planter press wheels, smooth or lug? in reply to JWS, 04-16-2001 14:06:35
If you should need some, I've got good ones by the dozen.....scrapped out many planter thru the years.....
Rick
04-20-2001 16:41:39
The lugs are there to drive the herbicide and insecticide....
Mike
04-17-2001 04:18:39
I have a 494A too, and have smooth rubber press wheels, work well but are cracking, do you know if they are still available.
Dave S. from PA.
04-17-2001 17:52:23
 Re: Re: Rubber planter press wheels, smooth or lug? in reply to Mike, 04-17-2001 04:18:39
Here in Pa. we have a place called Central Tractor.I believe they have both lug and smooth in stock.They also should be available from JD.
paul
04-18-2001 09:54:26
 Re: Re: Re: Rubber planter press wheels, smooth or lug? in reply to Dave S. from PA., 04-17-2001 17:52:23
Shoup sells all kinds of planter parts, altho older than 7000 series is getting hard to find parts for...
I think very little difference on type, would put the better set on. If they are the same, then I might lean towards the smooth - grips will pick up & hold a little more silty mud. Maybe. But in the real world, not much difference.
--->Paul
RayP(MI)
04-16-2001 19:05:02
Probably doesn't make a whole lot of diffeence.
