JD Rake
HUBB
04-09-2001 21:25:52
Anyone know approximately when the JD 350 3ph rake was made? Is it a decent choice for 20 acres of haymaking? Thanks.
Fudd
04-10-2001 19:47:16
 Re: JD Rake in reply to HUBB, 04-09-2001 21:25:52
I have a 3 point 350 and it works good but I don't rake very fast. I grew up with a pull type rake so I had trouble getting used to the 3 point setup. I don't like the fact you have to raise it up to back up, the wheels in the back sill not swivel 360 degrees.
JD70Jim
04-10-2001 07:40:58
Introduced about 1957. They came in 7' width, could be 3 point or semi-integral, were PTO driven and could rake at up to 6 1/2 mph. Not a good match for a 9 foot mower, but if you use 7' they aren't bad. We used a semi-integral one in the 60s to 70s. It did fine work, except whenever you ran those small rear wheels over a rut or a hole, they tended to break castings real easily.
