JD rake info
CDH
03-27-2001 16:33:41
neighbor gave me JD rake last month been setting in woods for 15 years rubber tires 15"front 8"rear gear box driven 3 leavers casting #range fromC335E to C484E rake is in excelant condtion for setting that long would like model# and years made thanks in advance CDH
leroy
03-27-2001 19:05:19
 Re: JD rake info in reply to CDH, 03-27-2001 16:33:41
Check that back tire size again, they used a 9" not an 8" on a lot of them, 9" is what mine has.
Tim(nj)
03-27-2001 17:25:30
594LW. Rubber tired version of steel-wheeled inclined frame rakes from the 590 series. Last of the line. Sold from about 1948 to 1959.
CDH
03-28-2001 03:19:59
 Re: Re: JD rake info in reply to Tim(nj), 03-27-2001 17:25:30
I thank you fellows for the info on my rake Leroy you are right the tires are 400x9 and hold air good if my memory is correct you can use it as a fluffer or tetter also thanks again CDH
