JD24W $$
Red Rookie
03-26-2001 05:49:57
Looked at a JD 24W baler and a NH model 56 rake this weekend. He wants $1,100 for both pieces. I have about 60 acres I would like to bale. I've never done this before and need help. Is this a good price? He has all the manuals for his equipment and used it last year with no problems. Would that model hold up if I baled 60-90 acres a few times a year? Thanks in advance. RR
Bill
03-26-2001 13:10:35
 Re: JD24W $$ in reply to Red Rookie, 03-26-2001 05:49:57
The equipment will probably hold up, but the bigger question is whether you will hold up trying to square bale 60 to 90 acres of hay, 2 or 3 times a year. That's alot of work! Hope you have plenty of good dependable help...you'll need it! If you're in an area that gets any amount of rain each year, those square bales need to be stored inside,unless you have some really good tarps to cover any outside stacks . A wire tie baler probably will make heavier bales than twine tie baler, so there's something else to consider.Lots of lifting and lots of luck!
