What Type Of Plow to Use?
george
03-09-2001 07:33:09
I want to break some ground for a garden in grassy, but rocky soil. What style of plow (or discs?) is preferable?
Bob McCammon
03-10-2001 17:09:41
 Re: What Type Of Plow to Use? in reply to george, 03-09-2001 07:33:09
If the rock is solid outcropings then your only choice is a disk plow. If the rocks are say "fist size" the the moldboard will work well. Good luck and take your time.
Tom from Ontario
03-09-2001 19:56:18
Whatever you use, take it slow. Get as many rocks out of your area asap. They are expensive.
Lyle
03-10-2001 08:25:14
 Re: Re: What Type Of Plow to Use? in reply to Tom from Ontario, 03-09-2001 19:56:18
I would use the moldboard type plow for a couple of reasons. You can get and old pull behind plow very reasonable and if your only going to plow a garden, it is simple and quick to hook and unhook and put away for next year. The only thing is you have sod to plow under, it should be plowed and left lay until the sod decays. This will take quite a while. I usually plow down sod in the fall and not harrow until the following spring. You soil will work up good then without to much sod turning up when you do harrow or disc.
sammy the RED
03-09-2001 13:40:24
Moldboard.
george
03-12-2001 06:28:32
 Re: Re: What Type Of Plow to Use? in reply to sammy the RED, 03-09-2001 13:40:24
Sounds good! Thanks for the advice!
