Moldboard, disc plow, and trailer type plows
Paul Stanley
02-24-2001 11:01:21
I love antique tractors, but never did any farming. (not all of use are that lucky). I would like to know a more about different types of plows. I have an Oliver Super 55 that I am restoring, but I do use it around my small acerage whenever possible. I am curious about plows. What would be the advantage of any of the different plows over the other and what are the different intended uses for them. Thanks for any information. Any recommend resources such as books or webpages would be appreciated. Email me if you prefer.
Roger
02-25-2001 06:54:42
 Re: Moldboard, disc plow, and trailer type plows in reply to Paul Stanley, 02-24-2001 11:01:21
Shawn has a good point about the trip rope. You should always use a peice of baling wire with a hook on the end of the rope so it will not damage anything. No one mentioned disc plows. These were used in rocky areas since they would go over an obsticale in the soil. They would also cut when the ground was to dry and hard for a moldboard plow. The problem with disc plows is setting one. I have several and getting one to stay behind the tractor is a real job. If your soil is all the same type they are easy to set, but if you have light to heavy soil it changes the draft.
ralph hart
04-29-2001 22:11:57
 Re: Re: Moldboard, disc plow, and trailer type plows in reply to Roger, 02-25-2001 06:54:42
I have a minneapolis&case plows that i need moldboards for could anybody tell me who is still making them
Charlie
02-24-2001 11:35:16
A moldboard plow is any plow that turns dirt over - it can be a trailer plow or a mounted plow. Areas that have very light soil are getting away from moldboard type plows as its too easy for the top soil to blow away. If your tractor doesn't have a 3 pt hitch then what you need is a trailer plow. I think trailer plows do the best job of plowing but one of the big disadvantages is you can't back them up like you could a mounted plow. A mounted plow also adds some weight to your tractor which can be helpful.
shawn
02-24-2001 19:43:42
 Re: Re: Moldboard, disc plow, and trailer type plows in reply to Charlie, 02-24-2001 11:35:16
I have a JD trailer plow and it is good.The big advantage is the hook up, just one pin. Also it is easy to set the depth and it breaks away if you snag something hard(no tractor damage caused)The disadvantage is the trip rope.If the plow disconnects the rope goes too, meaning you can't tie it to anything or the object you tied it to goes with it.
