Pitman arm
Bob A
02-20-2001 19:26:43
Is there a spacific reason that something other than hard wood can not be used for the pitman arm on a #5 JD mower? If the slip cluch is adjusted correctly why would'nt a steel pitman arm work? Thanks for the input.
Leroy
02-22-2001 19:47:49
 Re: pitman arm in reply to Bob A, 02-20-2001 19:26:43
Ford used steel
Moose
02-20-2001 20:26:35
There is a sudden shock factor that I believe appies. The clutch can not react quickly enough to compensate for a knife section suddenly locking against a guard. Clutch slipage seems to be designed more for too much material being forced through the mower and not for sudden obstruction. Rather than have a casting break, the designers opted to have the wooden arm snap. I remember my dad making replacements by hand to have at the ready.
Joe Evans
02-21-2001 20:26:01
 Re: Re: pitman arm in reply to Moose, 02-20-2001 20:26:35
Bob A is right. The wood pitman arm is the "fail safe" device to keep from tearing things up. My Dad got tired of replacing wood pitman arms in his old tow-type New Idea mower and fashioned one using 1-1/2" pipe. After 2 or 3 snapped knife sections he went back to wood although he used a pick handle for the pitman arm.
dan
06-28-2001 08:26:45
 Re: Re: Re: pitman arm in reply to Joe Evans, 02-21-2001 20:26:01
yes i use white oak it works just fine and have them custom made
mike jenezon
02-23-2001 23:05:02
I have two mowers one massy one case and got tired of the wood deterirating and made pittmans out of 1x1 aluminum about .120 wall it will generally still break before a knife but way stronger than wood and it doesn't rot
John Porter
06-06-2002 14:47:43
 Re: Re: Re: Re: pitman arm in reply to mike jenezon, 02-23-2001 23:05:02
PA inspection requires a pitman arm for a '75 Dodge Midas Motorhome. Other than a machinist
mfg the device, is there a method of ordering pitman arm thru Dodge?
John Porter
06-06-2002 14:37:52
John Porter
06-06-2002 14:30:30
John Porter
06-06-2002 14:28:23
