Small Hyd. Dump Trailer
RWK in WI
02-18-2001 06:38:03
I am looking for a small ( 3' X 5' to 4' X 6' ) trailer with at least 14" or 15" wheels that I can use behind my tractor that would dump by hydraulic lift. It's one thing to toss stuff on the trailer but a real pain to have to unload by hand. Has anyone built or seen something like this.
Joe Smith
04-13-2002 20:38:21
 Re: Small Hyd. Dump Trailer in reply to RWK in WI, 02-18-2001 06:38:03
E bay has one for 1100.00
Alvin
02-18-2001 18:12:03
Check the Wis. Farmer or agri-view paper. there is a company by the name of Sands that makes a nice trailor.Bought one about 10-12 years ago , use it to haul stones ,wood or anything that you can throw or dump on it and want to haul away and dump . Made good.
Joe
02-18-2001 17:35:48
A couple of years ago I built a 4X8ft dump trailer that works real good.I started with an axle from a 3/4 ton truck. Just pull out the axle shafts and cut the end plates off. Then put the plates back on. Then I made a frame with 6" channel iron. Weld the axle right to the frame no need for srings. I made a box out of 10" jr I beam. Use 2" angle for cross members and 3/16" steel for the floor. To finish I used a hoist that came out of a grain wagon. This work good for hauling dirt and picking stones. Hope this helps.
taylor Lambert
02-18-2001 16:39:57
Yahoo clubs has a home built implements page its very good has a few pics off home built dump trailers. I make them for refuse and brush hauling from halves of purged propane tanks. with one end cut out.
Keewaydin
02-20-2001 08:57:17
 Re: Re: Small Hyd. Dump Trailer in reply to taylor Lambert, 02-18-2001 16:39:57
Could you supply a web site address for the Yahoo Club that talks about shop built implements? When I tried to find it I got so much info on Yahoo clubs that I never could narrow it down to the one you referred to, Thx
F14
02-18-2001 07:53:32
Northern Tool has a nice trailer, with a kit to convert it to hydraulic dump. Check the link.
