PHD Questions and Information
Keith B
02-16-2001 05:26:10
I'm looking at buying a 3pt post hole digger to use behind my Farmall 560 (Currently has a Fast Hitch but will either have a 3pt or at least the adapters).
What should I be looking for as far as gear box and such? Also, I'm assuming these things all have shear pins of some sort. What brands should I consider and what brands should I steer clear of? Any and all advice is welcome.
Sid Miller
02-16-2001 11:48:31
 Re: PHD Questions and Information in reply to Keith B, 02-16-2001 05:26:10
I have a 350IH utility with a coupler adapter for the fast hitch and a ford digger that will not fit on the tractor with any amount of modification.So, make sure your digger will fit your hitch arrangement.Good Luck.
Sometimes Wrong But Never In Doubt
02-16-2001 13:35:38
 Re: Re: PHD Questions and Information in reply to Sid Miller, 02-16-2001 11:48:31
Shoot, when I saw your topic I thought you were seeking an advanced academic degree. Farmers know what BS means. MS means More of the Same. PHD means Piled Higher and Deeper. Any more questions?
