Silo
dross
02-13-2001 20:26:28
got a different one for you all. had a drain fill
with ice, during a thaw in Jan. It backed water into our silo, through a fan opening, the bottom of this silo holds
about a thousand bushel to ground level. the problem is that water froze the only two augers out of the silo. I want to run that fan backwards
and put a nipco heater on it, keeping the heater back far enough to regulate the inlet temp to about 70 degrees, try to thaw it out. Any body got
a better idea. PS no, waiting for june is not an option. Thanks,dave
