Plow Point (Share)
Doug
02-10-1999 11:39:27
Does anyone where I can get a cast iron point (share) for a Dearborne 2 bottom plow. The numbers on the point I have are: 100962
12 BC AO 181 DDS
Thanks for your help.
Bob Brown
11-28-2002 13:48:30
 Re: Plow Point (Share) in reply to Doug, 02-10-1999 11:39:27
Check with Farmer Brown`s Plow Shop at we stock a lot of old cast and steel points.
Bob Brown
11-28-2002 13:45:49
Check with Farmer Brown`s Plow Shop we stock a lot of old cast and steel points.
Don H.
02-15-1999 17:46:01
Where do you live? You might try your local Ford/New Holland dealer. If that doesn't work and you live in the midwest, you can try either Farm and Fleet or Fleet Farm. Another one is Tractor Supply and still another option is Central Tractor, either in their catalog or in one of their several stores. There are probably other options too, but these are the ones that come to mind for me. Good luck.
