Sprayer pump
Rob
02-09-2001 09:20:26
I recently recieved a sprayer pump from a friend & am trying to figure out the basics about this pump. How many gpm, you know that type of stuff. The sticker that would tell me all that is half way ripped off. All I can maye out is "Red Li". If you can tell me a manufacturer that name starts something like this, let me know.
Ray,IN
02-09-2001 10:55:31
 Re: Sprayer pump in reply to Rob, 02-09-2001 09:20:26
Red Line pumps are still made. Check with a large implement dealer who sells pumps. Watch the cost though, a new pump may be bought for nearly the same money sometimes.
Rob
02-09-2001 17:38:06
 Re: Re: Sprayer pump in reply to Ray,IN, 02-09-2001 10:55:31
That's what I thought the name was, but I'm unfamiliar with the sprayer market. I have just tore the pump apart. I'm sure the original seals are in there, but I am debating to replace them. The bearing are junk, all gunked up from the chemicals. I appreciate the information. Is there anyway I can find out how many gpm @ Rpm's without a serial number?
Ray,In
02-10-2001 18:52:55
 Re: Re: Re: Sprayer pump in reply to Rob, 02-09-2001 17:38:06
A new 12v pump (diff. brand) for ag chemicals is $60-90 bucks. How attached to the Red Line are you? I believe Red Line is a top of the line pump, which means $$$$$. Check out prices and determine your options.
Rob
02-11-2001 12:13:42
 Re: Re: Re: Re: Sprayer pump in reply to Ray,In, 02-10-2001 18:52:55
I really don't know much about this stuff. I'm building a pull type sprayer & this pump was given to me. I am pleased to hear that I have a top of the line pump. Yet, I have done some research on a 12-volt pumps, which the are cheaper like you wrote. I'll let you know how much bearing & seals cost.
