J.D. 1209 Swather
Scott
02-09-2001 08:33:05
Trying my hand at putin up Hay this year. Have about 20 acres of brome,Alfa,clover mix. The swather is a 9 footer and Ive read, reread and familiarized myself with it the best I can without actually running it. Now I Know Experience is tons better than manual reading. So looking for those experienced people that can pass on some of those hints and pointers in running this thing.
Thankyou
Scott
Tim(nj)
02-09-2001 19:09:06
 Re: J.D. 1209 Swather in reply to Scott, 02-09-2001 08:33:05
Keep the head bushing well greased. Also make sure that you have the weight adjusted evenly on the skid plate, or it will wear unevenly and cause the machine to cut unevenly. Mine had a skid plate that was 75% on one end and worn through on the other end because the previous owner had never checked the adjustment. Also check to be sure that the reel teeth do not hit the cutterbar. Mine was out of adjustment there, as well.
gary sanderson
04-05-2006 20:32:39
 Re: Re: J.D. 1209 Swather in reply to Tim(nj), 02-09-2001 19:09:06
need cutter parts for a 1209 can you help me find them thanks gary
