Trailer rims
The immigrant
01-30-2001 20:26:49
recently bought a barn with an old trailer thats been sitting. The tires and rims are 480-8 that are dryrotted. these are high speed road tires that i dont need. i want larger tires and rims for general hauling around the farm. They are four hole rims. Will a four hole 14" car rim and tire fit these hubs, there seems to be plenty of clearance to accomodate larger tires????? ???/
Shopguy
01-31-2001 04:06:47
 Re: trailer rims in reply to The immigrant, 01-30-2001 20:26:49
The trailer hub is likely larger than the centre hole in the car rims.You can buy larger trailer rims.Try www.princessauto.com.
Al
BFO
01-31-2001 04:46:15
 Re: Re: trailer rims in reply to Shopguy, 01-31-2001 04:06:47
The largest 4 on 4 rim Princess Auto has listed is a 13 X 4.5 part #2020018. I was looking at the catologue of the people who supply Princess Auto. OEM pricing is a little better ;-)
BFO
01-30-2001 20:41:32
What you most likely have are 4 on 4" bolt circle hubs, don't know if there are 14" rims with that pattern. The largest my book shows is a 13 x 4.5 rim for a trailer application. HTH
Bus Driver
02-02-2001 07:05:32
 Re: Re: trailer rims in reply to BFO, 01-30-2001 20:41:32
It would be wise to assume that the 13" tires will handle all the weight that the axles can handle. Most of us judge the loading of a trailer by looking at the tires. These are most likely low weight rated axles.
BFO
02-02-2001 11:30:59
 Re: Re: Re: trailer rims in reply to Bus Driver, 02-02-2001 07:05:32
The capacity of the tire will probably exceed the axle rating. The 13 X 4.5, 4 bolt on 4" centre, wheel is rated for 1100lbs. It would be a good idea to check the VIN plate and determine axle capacity. However I would recommend the larger tires as there is less wear on bearings due to larger diameter, slower running speed.
