JD plow id
rhudson
01-28-2001 18:06:04
never thought i would buy an old plow but.. i just purchased a trailor type 3 bottom plow. rubber tires on round spoked wheels has a pawl handle on the right side and a place for a hydraulic cylinder on the left. hitch has a bar to vary the offset of the plow. its green, could not find a tag or numbers. how can i identify it?
thanks, robert
rhudson-thanks
01-30-2001 13:15:19
 Re: JD plow id in reply to rhudson, 01-28-2001 18:06:04
55H it is. the guys at john deere were amazed. they just didn't think a guy as dumb looking as me had the backing of fellows as sharp as you. thanks Mark and Bob
mark
02-03-2001 12:47:04
 Re: Re: JD plow id in reply to rhudson-thanks, 01-30-2001 13:15:19
No problem I'm just happy that some one has the same intresests as I do. Glad to be some help
Mark
Bob Collins
01-29-2001 12:03:01
Robert, Mark gave a good start to identify your plow. If the main frame members are made of 2 3/4" x 1" stock it is likely a 55H they were made in 3bottom 12-14-16" sizes. The 66H was made from 3"x1" stock and came in 3,4,and 5 bottom sizes. 555H was like th 55 but with trip back standards, roller bearing wheels and was made in 3 or 4 bottoms. Get some casting numbers from as many places as possible (hubs, rear wheel support etc.) and we can pin it down better. Bob
rhudson more info
01-29-2001 16:02:09
 Re: Re: JD plow id in reply to Bob Collins, 01-29-2001 12:03:01
thanks fellows
"rear wheel caster" casting G-801-A
"rear caster to beam" casting G-717-A
"hub cover" casting D-928-A marked JD
"manual lift pivot" casting D-936-A
beams are 1" x 2 3/4"
plow points are non-trip
Bob Collins
01-30-2001 09:20:36
 Re: Re: Re: JD plow id in reply to rhudson more info, 01-29-2001 16:02:09
These are all part/casting numbers for parts that would be found on a 55B plow made 1945-1960. Get a parts catalog number PC-178 and you can see just what you might be missing. Good luck. Bob
mark
01-28-2001 18:50:23
The plow you are describing sounds like a little brother to a 55H, 4bottom , 66H, 5bottom, or a 77H, 6bottom it could be a 44H I am not 100% sure but I know our own 4bottom 55H is a rubber tire on spoke rims and has a cylinder lift and a leveling lever on some the rear wheel was solid steel and others was a 4 bolt rim with a rubber tire on it. The "H" in the model numbers says it is a hydraulic lift
Mark
