Pull behind mower
Martin Kellner
01-17-2001 13:21:38
Were the original mowers designed for a 1953 Farmall Super C attached to the 2 point fast hitch or pulled from the draw bar. Where might I find a new mower that can be pulled from the draw bar? If I get a 3 point hitch, will the Super C hydraulics lift a 5 foot mower? Thanks for all responses. -- Martin
tim(ny)
01-18-2001 06:10:59
 Re: pull behind mower in reply to Martin Kellner, 01-17-2001 13:21:38
I have a mounted mower for my Super C that I got off a C. It clamps onto the axles and just hangs there, no trailer wheel or anything to help support it. That's a problem, because its starting to sag with old age. Its not on the tractor now, but I can send you a pic if that will help. Email me if you'd like one. I don't know what other options were available. The guts are the common IH style mower.
Chuck
01-18-2001 05:58:52
1.I'm not familiar with IH pull behinds for Super C.
2. Bush Hog,John Deere,King Kutter all make pull behinds. Check their webb sites for size and model #'s, then call local dealers for price and availability. Around here 5' King Kutter with slip clutch and solid tires are about $1000.00 new.
3. Yes, the hydraulics will lift a 5' 3pt if you have a 3pt hitch.
Hope this helps.
CB
