Riveting jd spreader floor
k-gump
01-15-2001 14:16:03
Anyone have an idea of where to find the flat head rivets to attach the moving floor boards on a john deere E horse drawn spreader?. Or know of another way that will at least look original, besides the usual baling wire trick?. Bolts and nuts won't agree with the rollers. Any ideas?
RayP
01-15-2001 18:01:36
 Re: riveting jd spreader floor in reply to k-gump, 01-15-2001 14:16:03
Would carrage bolts work?
Shep
01-15-2001 17:22:39
Check you local airport - municipal or commercial. Ask to speak with someone in Air Frames.
They should be able to give you a handful or either flush rivits, blind rivits, or Hi-locks.
Used all of the above on a variety of projects car, truck, sheds etc. I was a Navy 'tron who assisted sheet metal guys. Caution on hi-locs, they are extremely durable and nearly impossible to remove, they also extend approx. 1/32 - 3/4" depending on shank length.
HTH,
Shep
JR
01-16-2001 12:28:57
 Re: Re: riveting jd spreader floor in reply to Shep, 01-15-2001 17:22:39
I thought they where called ny-locks because of their Nylon threads. They are hard to back off too and can't be turned by hand hardly at all.
Shopguy
01-15-2001 17:14:56
Try spaeneaur,not shure if they are on the web but worth a look.
Al
Shopguy
01-16-2001 07:59:49
 Re: Re: riveting jd spreader floor in reply to Shopguy, 01-15-2001 17:14:56
Post exactly what you want,I will bring a cataloge home and let you know what is availiable
Al
kirk
01-19-2001 06:16:04
 Re: Re: Re: riveting jd spreader floor in reply to Shopguy, 01-16-2001 07:59:49
thanks for the suggestions everyone. carraige bolts won't work nor would anything needing a nut.
i thought of something yesterday, should have thought of it before. "elevator bolts" i used them at a grain elevator manufacturing company to fasten rubber tread to steal pullies and to attach cups to the rubber belts. i'll use a 5/16"x 1" bolt and peen it over on the underside.
they have large flat heads, and come i galvanized.
outa be about right to attach the 3/4" boards. i need 96 so that should be a cheaper way too. thanks for the quick responses. if someone has a better idea i'm listening it will be a long while before i'll be at that point in restoration. this is a jd model b horse drawn spreader just for reference to other restorers.
