PULL BEHIND BUSH HOG
JILL STROUD
01-14-2001 13:04:15
DOES ANYONE IN INDIANA OR SURROUNDING STATES, KNOW WHERE I CAN LOCATE A PULL BEHIND BUSH HOG.(5 FOOT)? I HAVE A 1948 FARMALL "H" WITH A TRAILER TYPE PULL HITCH. THANK YOU!! JILL STROUD
ed
01-14-2001 21:34:28
 Re: PULL BEHIND BUSH HOG in reply to JILL STROUD, 01-14-2001 13:04:15
Jill, there are many units out there beaware that a good unit (if found) should have a two part pto. I have two and I use the one that the pto is a two part unit. The long one will bind when turning if you don't disengage the pto. I know from experence the hard way. The only fix to my tractor was to open up the pto and repair. I hope you find what your looking for. ed
RickB
01-14-2001 13:23:58
Bush Hog sells pull type cutters.
