Northern tool
nodak
12-07-2000 20:47:19
does anybody have any expereance with there implaments? thanks
g
12-08-2000 12:20:25
 Re: northern tool in reply to nodak, 12-07-2000 20:47:19
I've purchased two implements from them...a single row cultivator and a shank subsoiler. The products were made by Vasser. They are medium duty CAT 1, rated for 40HP. The cultivator is a bolt-together set-up, and I've used it quite a bit for loosening soil and pulling rocks. The subsoiler is a welded set-up. They're ok, but if you plan to work the stuff hard, I would shop elsewhere, especially if you wand a box or grader blade...they're made of thin plate steel and may not hold up.
