Loader for Ford 601
Spencer
12-07-2000 16:40:53
I recently bought a front loader for my 1958 Ford 601. I'm pretty sure of where to connect the pressure line. There is an accessory plate just behind the transmission. It has a fitting that is plugged and a knob. But I don't see where to run the return line from the loader. Please help.
Spencer
VIC
12-10-2000 14:26:07
 Re: Loader for Ford 601 in reply to Spencer, 12-07-2000 16:40:53
Don't you need a pump powerd off the front of the engine ?
Spencer
12-10-2000 18:36:38
 Re: Re: Loader for Ford 601 in reply to VIC, 12-10-2000 14:26:07
No. I can connect the pressure line to an accessory plate on top of the hydraulic resevoir. Next to the fitting is a diverter valve. With the valve out, pressure is directed to the loader. With the valve in, pressure is directed to the 3-point hitch. I went to a Ford Tractor Dealer and they suggested that I drill and tap a hole in my hydraulic filler cap and run the return line into there.
