Removing wheel on JD Model 44 plow
Dick N
11-24-2000 09:05:47
I have removed the pin and the collar but the wheel will only come off a little ways. This is on the lift side of the plow. What do I need to do to get it off? Thanks in advance for any help>
Craig
12-01-2000 20:17:20
 Re: Removing wheel on JD Model 44 plow in reply to Dick N, 11-24-2000 09:05:47
That wheel is a taper fit on to the clutch hub inside of the lift clutch housing. Don't know if I called it by the right name. I worked on one a few years ago but at that time I did not know it was a taper fit. Is there 3 bolts going through the wheel hub to hold it all together? I don't remember.
D Cotton
11-25-2000 12:57:32
It took a gear puller and some time but I hooked up the gear puller to the hub and pulled against the axle with spraying lube. Took 3 days of taking up the slack and it pop off in the night.
Dennis
Karl Bader
11-24-2000 10:53:30
I have a NO. 44 plow. e-mail me and I can help you. I can even send you copies of the nessesary pages out of the manual to help you.
Thanks,
Karl
