Pasture roller
Jim Holm
11-14-2000 10:05:00
I am looking for a roller to use with my 27hp Ford 4wd 1715 tractor. Does anyone know of a manufacturer? Should I try to build one? If so, any suggestions on a design / parts etc? thanks
Kermit
11-14-2000 14:54:11
 Re: pasture roller in reply to Jim Holm, 11-14-2000 10:05:00
There is probably a welding shop located near you that would build a roller. I live in SW MO and there is a shop located about 40 miles away that builds a very heavy roller and will deliver if needed. I'm sure there is someone near you that either manufactures rollers or will build one on request. Be sure to tell them about your tractor so they don't build one too heavy for it to handle safely.
george
11-16-2000 13:20:07
 Re: Re: pasture roller in reply to Kermit, 11-14-2000 14:54:11
A heavy roller is not necessarily the best thing for grass. If soil is too tight, it will not allow the roots to develop. A roller's weight should be relative to it's width, no more that 20 lbs/ft. Perhaps you can use a lnadscape rake to level the ground, and only roll lightly.
