New Holland bale wagons....which ones were good?
TB SCOTT
11-02-2000 14:11:10
Regarding the new holland bale wagons.....i would like to get one that unloads one bale at a time. What models do this and which models should I stay away from. thanks !!!!! ! :-)
Tom from Ontario
11-04-2000 16:58:52
 Re: New Holland bale wagons....which ones were good? in reply to TB SCOTT, 11-02-2000 14:11:10
I had a model 1012 wagon and it was a peach. The most trouble I had with it was my own fault. They take a bit of learning but the most critical element is the baler ahead of it. You MUST make good square uniform bales. If you don't do that, the bale wagon will not work, period. You should also follow the path of the baler, don't go after a stray row of bales just because they are there. The only expenses I ahd with were shear bolts when I whomped it into a groundhog hole now and then and a cable for the main deck. I used to do about 7000 bales a year myself and did not break a sweat. Great machine. Good Luck. Tom
