Manure spreader New Idea?
Brian
10-28-2000 17:24:00
It has a 8ft wooden bed, is ground driven, and has cast iron wheels with 20 in rubber. The color was an orange. I am missing the drive mechanism for the floor, it has 3 lobes on the left side that some how drives the floor. the rest is missing,some one changed the gear with another and I believe they apparently drove it with a gas engine, or tryed anyway. Where can I find pictures so I can fabricate the missing parts? Any help would be appreciated.
F14
10-29-2000 03:29:20
 Re: Manure spreader New Idea? in reply to Brian, 10-28-2000 17:24:00
If you can post a picture of the spreader, more than likely someone can identify the model, then perhaps you can get a manual from a dealer. I just did for a 50+ year old John Deere.
The three-lobed cam (I'm assuming it's mounted to the axle, between the wheel and the frame) was used to drive a ratchet assembly that moved the apron chain a certain distance every time it rode up over a lobe on the cam. I can get some pictures of how it works on my JD if you think that would help.
BFarr
10-30-2000 15:54:26
 Re: Re: Manure spreader New Idea? in reply to F14, 10-29-2000 03:29:20
By your description, I have a similiar model in the barn. If you can post a picture before snow
I will verify and return a closeup picture
