Removing post-hole digger auger
Willie
10-23-2000 13:16:31
I have a post hole digger(3 pt hook-up) that I bought new in about 1973. All I can read on it now is 'Star Incorporated'. Question: How do I get the auger off? I took the shear bolt out up near the gear box and the auger turns on an inner shaft with the help of a pipe wrench, but where is the bolt or nut holding the auger skin on the inner shaft? I need to put a new seal in the bottom of the gear box.
Scott HouTex
10-25-2000 15:46:05
 Re: Removing post-hole digger auger in reply to Willie, 10-23-2000 13:16:31
My Danuser auger bits have a second short bolt
that engages a groove in the shaft just above the shear bolt. This bolt will keep the bit from
falling off if you shear the shear bolt.
Willie(Conroe Texas)
10-28-2000 09:27:59
 Re: Re: Removing post-hole digger auger in reply to Scott HouTex, 10-25-2000 15:46:05
Thanks! It's a done deal. There was a rolled-pin just below the shear bolt that would rotate in a concave slot, holding the auger on the shaft. Everything was so covered w/grease it was hard to find. Popped right out and auger popped right off.
F14
10-23-2000 13:46:56
If you can turn the auger without turning the gearbox shaft, it ought to come off. Probably just corroded up or there's a burr on the bolt hole through the auger and the gearbox shaft. Try being a bit more 'persuasive' with it. Also, a couple of squirts of penetrating oil couldn't hurt.
Al
10-23-2000 19:14:41
 Re: Re: Removing post-hole digger auger in reply to F14, 10-23-2000 13:46:56
There more than likely is a snap ring to hold it on the shaft.
