Modifying a disc-question
DaveK(IN)
04-21-2010 17:39:59
I have a disc that measures 8" across the rear set of discs when they are straight. I noticed tonight that the rear set has 7 discs on each side and the front section has only 6 and therefore is a little narrower. I have been pulling this around with my Farmall C for years. Now my acreage is in hay and the only thing I use my disc for it preparing the garden. Here are my questions.
1. Why is the rear gang one disc larger?
2. I want to downsize the disc to make it easier to use in the garden. Can I remove a disc or two from each gang and replace them with a spacer of some sort? A five or six foot disc would be plenty for the garden and much easier to turn. This is a plain pull behind with no lifting mechanisim of any kind.
Thanks in advance for any advice.
