Need info on John Deere KBA disc
Jack
10-19-2000 19:23:11
Can anybody tell me when the KBA 10 foot disc was made? also need to know what size blades it takes. What is one of these discs worth in very good condition
Drew
10-20-2000 05:58:11
 Re: need info on John Deere KBA disc in reply to Jack, 10-19-2000 19:23:11
The KBA was made between 1948 and 1968 and had different size blades.
Jack
10-20-2000 07:52:42
 Re: Re: need info on John Deere KBA disc in reply to Drew , 10-20-2000 05:58:11
I measured the blade from side to side and it came out to 17 inches but I can't find any 17 inch blades. could this be an 18 inch blade.
Norm
10-20-2000 15:36:43
 Re: Re: Re: need info on John Deere KBA disc in reply to Jack, 10-20-2000 07:52:42
probably
Tim(nj)
10-20-2000 18:50:08
 Re: Re: Re: Re: need info on John Deere KBA disc in reply to Norm, 10-20-2000 15:36:43
Mine has 20" blades . . . .
You can put any size blade in that you want, provided the overhead clearance is sufficient and you can get that diameter blade with the right size hole in the middle. Can't remember offhand the KBA axle size. 1-1/8"?
