IH No 27 VA sicklebar mower
need help please.
Pete in PA
10-16-2000 14:06:34
Hi all...
With some help from the good folks on the farmall board, I was able to get this thing successfully mounted on my Farmall "H" - I now have more questions though about its operation...
This is a drawbar semi-mounted 7' sicklebar mower that has hydrolic lift and a wood pitman arm. The curious thing is that when I engage the hydrolic lift, the whole bar apparatus lifts horizontally off the ground about a foot or two. I was under the impression that this lift would actually raise the cutting bar from the horizontal position to the vertical position. Am I mistaken? Is something hooked up wrong?
Please help!
Thanks
Pete in PA
Karl Bader
10-17-2000 04:56:47
 Re: IH No 27 VA sicklebar mower - need help please. in reply to Pete in PA, 10-16-2000 14:06:34
That is right. It only lifts the bar a foot off the ground so you don't remow already mowed hay.
The rest of the way is on your own, be careful!
Hope this helps!
Karl
Norm
10-16-2000 14:23:20
They just raise about a foot off the surface. To get to vertical is manual. Watch your fingers.
