Old woods finish mower
adding wheels
ike
10-15-2000 19:53:01
have an old 6' woods finish mower (3pt. hitch, and about 20 yrs. old), but unlike today's newer decks, it only has 2 rear wheels... no front wheels. it does have a roller up front under the deck, but even adjusted out it's way too shallow (was this meant to be used as a front depth adjustment or???).
i'm thinking of adding 2 front wheels like the new decks, so it floats. right now, i have to ride the hydraulics over uneven turf.
any ideas on how to add the wheels or where to get some? any kits?
Robert
10-16-2000 16:29:46
 Re: old woods finish mower - adding wheels in reply to ike, 10-15-2000 19:53:01
I have added front wheels to Woods finish mowers two times. You can buy all you need from a Woods dealer. Thats what i did. You have to drill holes in the deck to bolt them on, but that's no big deal. Robert
scooterhead
10-16-2000 07:12:16
We have one like yours and the newer modle . the older modle needs adjustment chains that run from the front of mower to the tractors 3rd pt. link base , this hold front of mower up at disierd hegth . We have no problem with ours Hope that helps
Tommy D.
10-17-2000 06:09:13
 Re: Re: old woods finish mower - adding wheels in reply to scooterhead, 10-16-2000 07:12:16
Ok, I am still curious as to how this will help over uneven terrain. The front of the mower will still scalp when the front of the tractor starts up a hill.....
Thanks,
Tommy D.
Bayou Dave
10-16-2000 06:20:54
Ike, can you adjust the 3pt top link to get the front of the mower deck up?
ike
10-16-2000 18:08:55
 Re: Re: old woods finish mower - adding wheels in reply to Bayou Dave, 10-16-2000 06:20:54
i have the toplink adjusted.... the front of the deck sits just a little bit lower than the back - per the woods webpage.
i mow around many trees, and over some uneven terrain.... if the tractor goes up a grade before the deck, then it scalps... reverse happens when beginning down a grade.
another post mentioned limiter chains, but i'm assuming that would have roughly the same results.
i will probably go with the bolt on kit mentioned in the other post...
thanks to you and all for the help.
ike
