Mid mount implements
belly weights
Hartshorn
10-12-2000 06:00:15
I have a Ford 1500 4wd that is a bit on the light side. I also have some nice cut steel slabs that weigh 80 pounds each. I am wondering if there is a standard way in which mid mount implements are mounted. Are there usually attachment mounts built into the tractor? Are points actually drilled and tapped into the housing? (This would make me a bit nervous unless there are fairly standard places to do it) What I would like to do is make a belly mount bracket that I could essentially slide the cut steel (2" thick) into. They are 6x24 and such a midmount for weight seems like a good solution for a 4wd tractor. Would also keep the weight lower than the axles which also seems like a good idea and does not monopolize the hitch.
Thanks
Kim
