JD H Plow
Don
10-12-2000 05:03:05
My H has a single bottom plow mounted via a long bar which attaches to the main rails under the engine (2 bolts) and a hanging position mounted to a spring loaded lever mounted on the rear axle (no PowrLift). I'm trying to identify the Model #. The moldboard has a metal tab attached with the letters "1451, KN, SCPO" and the Gauge Wheel Hub has the following cast into it: JD C515A (on one side) and JD G514A (on the other side). In addition there is a sheet metal tab under one of the hub bolts with the letters (I think) "No 8, GWH". Thanks in advance to anybody who can help identify the plow and suggest where to get literature on it.
Don
grm
10-12-2000 10:53:01
 Re: JD H Plow in reply to Don, 10-12-2000 05:03:05
Your plow is a model H-1. Manuals are still available from JD. Call 1 800 522 7448
