MM corn shellers cylinder types? If so what model #'s were
Plow Man
10-11-2000 07:33:20
Were most MM corn shellers cylinder types? If so what model #'s were they. Around here the most common types that I see have the cob stacker and the cleaning fan up front, the grain elevator on the left side(looking from the front) with a long shoot, and the intake or feeder in the back. Sometimes the back can also have what I think is called a drag. If anyone can identify this corn shellers model #, please post a message. Thanks.
kev@IA
10-15-2000 11:20:51
 Re: MM corn shellers cylinder types? If so what model #'s were in reply to Plow Man, 10-11-2000 07:33:20
Try posting this over in the combine and harvester board. I am supprised on most being cylinder machines, would have thought they would use cage shellers like Woods or New Idea.
kev
paul
10-11-2000 20:47:49
The big fan up front was to pull the husks out & blow away. There is a little cleaning fan in the back, under where the ears elevate up from the drag. Also, there were different designs for the clean grain elevator - chain drive or belt drive. And some had a simple shoot on top, some had a horizontal auger gear driven.
Most of these aound here are a model 'D'. A bigger model was around too, um, 'E' I think. That evolved into the 1200, & 1210, which White put their name on at the end.
I run a D, I think I even have a manual for it.
--->Paul
