Need a Vermeer 605c expert !
Mark
02-01-1999 19:38:19
Last spring I purchased a 605c at a aution
under the guidance of a couple of friends that had round baler exsperiance. They said it looked like it had been takin care of and it ought to be a good one. Well it might have been me, but I have one heck of a time trying to get a bale started. I've tried every thing, going across the wind rows, weaving back and forth, going fast, going slow, going sideways, straight, etc. One thing I need to know about the belts , when you close the tail gate should the belts be loose or tight, I've heard both ways? Thanks for any help you can give !!
Pete
02-02-1999 05:05:05
 Re: need a Vermeer 605c expert ! in reply to Mark, 02-01-1999 19:38:19
If I remember correctly the one I had was a 605F. My baler did not like to start a bale if the hay was the least bit damp.Secondly it did not like small windrows. And third the belts should not be loose when gate is closed.
Don Summers
02-02-1999 19:51:28
 Re: Re: need a Vermeer 605c expert ! in reply to Pete, 02-02-1999 05:05:05
Belts should be tight when gate is closed, start windrow at one side of baler and zig all the way across and then back. Run at about 2/3 PTO speed until bale is started. They don't like damp hay, and they don't like real dry hay. I had one for 12 years and then traded for a Case-IH 8460. The rubber roll on top of the steel roller needs to be adjusted down fairly tight. Check the spring on it. Good luck!
